Electrical
Questions regarding electronics
<blockquote data-quote="lap202" data-source="post: 431471" data-attributes="member: 22187"><p>My motor is a pull to start 4hp so it doesnt charge the battery so will be charging the battery up at home. Was thinking about doing a 2 battery set ip with a switch to battery 1when switched to left, off in middle, and battery 2 on right so if the battery died i could switch over and make for home or stay out a bit longer.</p><p></p><p>Will use LEDs for all lighting to reduce draw.</p><p></p><p>Heres my layout as i see it.</p><p><img src="https://uploads.tapatalk-cdn.com/20170326/158a1d609a8f5914cee8022bd3781a1c.jpg" alt="" class="fr-fic fr-dii fr-draggable " style="" /></p><p></p><p>Sent from my SM-G900V using Tapatalk</p></blockquote><p></p>
[QUOTE="lap202, post: 431471, member: 22187"] My motor is a pull to start 4hp so it doesnt charge the battery so will be charging the battery up at home. Was thinking about doing a 2 battery set ip with a switch to battery 1when switched to left, off in middle, and battery 2 on right so if the battery died i could switch over and make for home or stay out a bit longer. Will use LEDs for all lighting to reduce draw. Heres my layout as i see it. [img]https://uploads.tapatalk-cdn.com/20170326/158a1d609a8f5914cee8022bd3781a1c.jpg[/img] Sent from my SM-G900V using Tapatalk [/QUOTE]
Electrical
