Boat House
Removing crease/scrape in an Aluminum boat
<blockquote data-quote="C&amp;amp;K" data-source="post: 483440" data-attributes="member: 30707"><p>Very easy to fix, but leave the dent itself alone other than sanding it to remove the oxide layer. Fill it with aluminum body filler (like USC all-metal works good). If the dent is in an area where it's painted you can repaint the repair. If it's bare aluminum (which most hull sheets are), you'll have to paint the hull bottom with either aluminum or stainless steel paint to hide the repair area, and which also with a good quality paint makes the hull look like brand new.</p></blockquote><p></p>
[QUOTE="C&K, post: 483440, member: 30707"] Very easy to fix, but leave the dent itself alone other than sanding it to remove the oxide layer. Fill it with aluminum body filler (like USC all-metal works good). If the dent is in an area where it's painted you can repaint the repair. If it's bare aluminum (which most hull sheets are), you'll have to paint the hull bottom with either aluminum or stainless steel paint to hide the repair area, and which also with a good quality paint makes the hull look like brand new. [/QUOTE]
Boat House
