rallypedigree
- Joined
- Oct 11, 2023
- Messages
- Reaction score
- 3
- LOCATION
- Atlanta GA
Hi all-first post and new to me boat. Could I replace this improvised Bus set up with a Blue Sea fuse block?
Left goes to motor, 25hp 2 stroke electric start with 6amp alternator
Right goes to battery cutoff switch (+) and battery (-) at bow. There is a 12v socket wired in as well just above.
The middle is just a piece of leather that hangs over the positive bus.
Trying to confirm if I could just wire the negatives to the negative pole on a Blue Sea, and the positives to the positive pole on the Blue Sea. Then add the socket to one of the fuses.
