Running an LCD off an inverter
JAS114
Stone Mountain, GA
I want to watch college football on the lake once in a while!
I have a 115 amp hour dual purpose deep cycle. It runs two fish finders (0.25A and 0.67A), a trolling motor (30A), and aerator (1.9A). I want to run a 15" LCD HDTV that draws 35 watts AC (0.30A). I have a 65W laptop inverter that will handle that no problem. I just want someone to verify my math here.
I think, if I plan to run the fish finders and aerator for 10 hours ([0.25A+0.67A+1.9A]*10hr=28.2AmpHrs), the trolling motor for 2 hours (2hr*30A=60AmpHrs), and the TV for 4 hours(0.3A*4hr=1.2AmpHrs), I'll have 115-28.2-60-1.2=25.6AmpHrs of reserve left.
I realize that I'm not accounting for the heat lost through the inverter, but basically, I just want to confirm that I'm right in my thinking that I'm gonna have enough juice to do this.
I have a seperate 24v system that just runs my bow mount, so I really won't even need to run the other trolling motor this long, but I want to be conservative so I don't run out of juice.
Thanks,
Josh
JAS114 said:
i figure i can toss a line during commercials, halftime....
I just want to be able say I did it!
In that case you'll get a lot of fishing done, as there seems to be more commercials runing than there are actual shows showing these days, lol. Hope it works out for you. 8)
buy a pocket handheld TV..
https://www.amazon.com/CTA-Digital-TV-P7-7-Inch-Handheld/dp/B0025VZPDE
this will work with the digital tv signals...
You can run an LCD off of an inverter but it must be a "true sine wave" inverter.No square wave or modified wave inverters.Be aware that the cheaper inverters have misleading info about this.Anything other than a true sine wave can cause poor functionality and possible damage to the sensitive electronics and the back light inverter for the screen.
The inverter is intended for laptop use. Wouldn't a laptop be even more fragile than a LCD TV?
