Boat House
Seats mounted to floor
<blockquote data-quote="lucescoflathead" data-source="post: 402896" data-attributes="member: 3558"><p>Cut a plate out of 1/4 inch aluminum a little bigger than seat mounting plate and drill the holes to align with the holes in the mounting plate. Put the plate under the floor the seat mount on top of the floor, drill holes in the floor and bolt together. Drill holes in your new flooring to align with your boat ribs and pop rivet in place. I use stainless screws and nyloc nuts. If you ever need to remove the floor, just drill the rivets out. Place the seat bases so they'll be between the ribs in your boat.</p><p></p><p>I've done three boats like this and never had a problem.</p></blockquote><p></p>
[QUOTE="lucescoflathead, post: 402896, member: 3558"] Cut a plate out of 1/4 inch aluminum a little bigger than seat mounting plate and drill the holes to align with the holes in the mounting plate. Put the plate under the floor the seat mount on top of the floor, drill holes in the floor and bolt together. Drill holes in your new flooring to align with your boat ribs and pop rivet in place. I use stainless screws and nyloc nuts. If you ever need to remove the floor, just drill the rivets out. Place the seat bases so they'll be between the ribs in your boat. I've done three boats like this and never had a problem. [/QUOTE]
Boat House
