Boat House
side reinforcement?
<blockquote data-quote="Captain Ahab" data-source="post: 409120" data-attributes="member: 10"><p>First of all what is your intended use for this boat? If you are using in smaller lakes and ponds you can get by with very little additional reinforcement. </p><p></p><p>Looks like you are running a 15 hp outboard? Is that correct - again, while perfectly fine to move the boat this small engine is not going to get you going all that fast hence less forces against the hull.</p><p></p><p></p><p>Some simple angle bracing might work fine.</p><p></p><p>Even better - add at least a casting deck and you will have no worries</p></blockquote><p></p>
[QUOTE="Captain Ahab, post: 409120, member: 10"] First of all what is your intended use for this boat? If you are using in smaller lakes and ponds you can get by with very little additional reinforcement. Looks like you are running a 15 hp outboard? Is that correct - again, while perfectly fine to move the boat this small engine is not going to get you going all that fast hence less forces against the hull. Some simple angle bracing might work fine. Even better - add at least a casting deck and you will have no worries [/QUOTE]
Boat House
side reinforcement?
