Wombat
- Joined
- Jun 1, 2013
- Messages
- Reaction score
- 0
I just bought an 1987 14' smokercraft and some of the cross supports are broken. How much of an issue is this? Can I use it safely for the summer? How hard would it be to fix? The middle seat also is not connected anymore at the center brace, how can I re-affix it?
Also it has a small leak on the riveted center bow bracket and another under the aft seat. What is the process to seal this and what should I use?
The wood on the transom where the motor mounts has worn through the fist layer of plywood. There is still a second under layer of plywood that seems to be solid. Also there is a good deal of patching done by the previous owner on the transom. The transom brace is still solidly in place. Would it be safe to put a 9.9 Nissan outboard on the boat or should I replace the wood before trying.
The stern corner caps on top are loose and so is the bow cap (not sure what to call them). Will just replacing the bolts be enough of a fix for use this summer? The handle is broken off of one of the rear ones. Where can I buy a replacement?
I hope to use it this summer and then do a real restoration this winter.
