old_school
- Joined
- Jan 18, 2011
- Messages
- 15
- Reaction score
- 0
quick specs - 1992 Sea Nymph - 1999 75hp Merc OB
water driven/tested before buying - transom seems solid
so I was taking off some old screws/hardware from the transom of the boat, saw what looked like a rust hole/pit hole about 1/4" in diameter, so I poke/dig around and there is lots of water and rotten wood in that immediate area (this post is more about the transom than the wood rot)
took a closer look at transom and there were about 4 other 1/8" holes in the same area (10" starboard of the motor - three quarters the way up the transom - scattered about in a 8" diameter area) - so I poke/dig around and water actually dribbled out of one hole and was able to easily pull out rotten wood out the others
QUESTIONS
1. what would cause the pitting/holes in the aluminum? (they are not from old mounts or hardware) - the Merc has anodes
2. when the motor is running and under power the transom does not move/bend - how do you know HOW SERIOUS the transom problem is? In the yard I can pull/push on the motor hard and not see the transom move.
3. I know aluminum welding is best for these holes/pits but if I am concerned about integrity of the aluminum sheet can I use Marine-Tex OR JB Weld OR stainless steel screws with rubber washers/sealant for these small holes? (we are taking off the 2.5" wide top aluminum transom cap/cover today to have a look down inside
4. when reinstalling the transom cap/cover what caulk do you recommend? Home Depot or West Marine stuff? It does not look like it was sealed before and I am sure water has been getting in under it.
Our Sea Nymph and transom is almost identical to the following repair post (an excellent post I must add)
https://www.tinboats.net/forum/viewtopic.php?f=3&t=13354
QUESTIONS
