I bought a new MK Edge 45 hand control bow mount last year. From the start I had trouble with the speed control. Things were fine for speeds 1 to 4,but when I twisted the grip for top speed (5), the motor dropped down to speed 3. If I twisted hard , sometimes I could get speed 5, usually not. It didn't happen all the time, but when it did it tended to stay that way for hours.
The MK phone rep was helpful; he sent me a new controller for the head; no fix. I sent the motor back and they couldn't make the motor repeat the problem (I've had hours at a time when it didn't happen). They problem eventually repeated when I put the motor back on.
I tried re-wiring my boat (battery to t-motor), in case I had a bad wire splice; no fix. I tried connecting the motor to another battery with just three feet of wire and no splices; it took a while but I got the motor to malfunction. At this point I called MK and told them I wanted a new motor. After some hesitation, they agreed and sent me a reconditioned motor (made my smile turn upside down). The new/reconditioned motor performs about the same! I get the lower speed on 5. If I twist hard it goes to 5. Then the problem goes away entirely!
Has anyone had this or a similar problem with Edge or MK motors? Could it be my boat wiring or battery, or is it more likely the motor? Any suggestions for diagnostics?
Tired of going slow.
Swump
Swump
