Stereo wiring
sworwa
Hey guys need some help on wiring up a stereo to a seasense switch panel. I have all the positive's running to a switch panel and the negatives to a buss bar. I can't figure out why I can't get my stereo to work, and I know its just the stereo because the lights and fishfinder are all running great of the panel now. I bought a basic, non-marine, pioneer stereo deck with two kenwood speakers. I connected the grey/white, grey, white, white/black wires off the stereo deck to the same colored wires running off the speakers, then ran the yellow wire off the stereo deck to the switch panel and the black wire to the buss bar, and nothing happened. Not sure if I wired it wrong but any help is appreciated.
Not sure if this helps you but I believe there are two power wires for a radio. One for keep alive memory and one for your main power. That might not be the right terminology but just make sure your don't need power to one more wire other than your yellow. Good luck.
Slough Runner, thanks for the tip buddy gave it a try and it worked right away!!
