Living in northern climes, it's coming up on that time of year--storing the outboard for the winter. My old 15 hp OMC 2 stroke, I'd just run the carb dry and store it inside upright, fresh lower unit lube, and start with fresh gas next season. It worked well.
I picked up a 2008 20 hp Tohatsu 4 stroke this year. Looking over the U Tube videos on motor storage, I saw that fogging seemed to be a good idea. So if I'm going to fog, is it better to run the carb dry and just fog the cylinders through the spark plug holes? Or do I need to squirt the fogging oil into the intake, while running, till it chokes, then do the cylinders, leaving stabilized gas in the system for the winter?
So fogging, do you? Is so, do store with gas in the system?
Do you have any issues upon startup the next season with the fogging oil in the system? My concern with the spray into the intake method, is clogging the carb jets with the waxy fogging oil, problem or not?
I've always thought that the best way to keep a carb clean was running it dry before storage. But maybe stabilized fuel works just as well?
I realize there may be no "right" way to do this. But I'm interested in your experiences and opinions. Thanks.
