Trailers
strange problem with CURT Custom Wiring Harness #56106
<blockquote data-quote="SeaFaring" data-source="post: 444258" data-attributes="member: 22876"><p>Since this is not 100% conclusively resolved, I’ll add two very simple suggestions that you probably tried in the beginning, mostly for the benefit of some future sufferer. </p><p></p><p>First, make sure your plugs are clean using electric contact cleaner and dielectric grease. This fixed an intermittent light problem on my boat trailer. </p><p></p><p>Second, always check your grounds with the wires plugged in but with the hitch unhooked. Intermittent grounding through the hitch concealed wiring problems on my utility trailer that advanced my hair loss considerably. </p><p></p><p></p><p>Sent from my iPhone using Tapatalk</p></blockquote><p></p>
[QUOTE="SeaFaring, post: 444258, member: 22876"] Since this is not 100% conclusively resolved, I’ll add two very simple suggestions that you probably tried in the beginning, mostly for the benefit of some future sufferer. First, make sure your plugs are clean using electric contact cleaner and dielectric grease. This fixed an intermittent light problem on my boat trailer. Second, always check your grounds with the wires plugged in but with the hitch unhooked. Intermittent grounding through the hitch concealed wiring problems on my utility trailer that advanced my hair loss considerably. Sent from my iPhone using Tapatalk [/QUOTE]
Insert quotes…
Trailers
