Boat House
Subfloor question
<blockquote data-quote="MrGiggles" data-source="post: 514836" data-attributes="member: 22613"><p>Splashwell. On many setups with an in-floor tank, the rear section runs underneath the splashwell, and that's where the fill, return, and pickup fittings will go. The filler neck often runs up through the splashwell, most pumps will reach there easily and you don't need to climb into the boat.</p><p></p><p>You can buy a screw in style fuel pickup assembly and put it pretty much wherever you want in that tank. The filler neck can be a little trickier, but still doable.</p></blockquote><p></p>
[QUOTE="MrGiggles, post: 514836, member: 22613"] Splashwell. On many setups with an in-floor tank, the rear section runs underneath the splashwell, and that's where the fill, return, and pickup fittings will go. The filler neck often runs up through the splashwell, most pumps will reach there easily and you don't need to climb into the boat. You can buy a screw in style fuel pickup assembly and put it pretty much wherever you want in that tank. The filler neck can be a little trickier, but still doable. [/QUOTE]
Insert quotes…
Boat House
Subfloor question
