Motors
top speed for a 1973 Evinrude 6hp on a Sears 12ft semi V
<blockquote data-quote="ohiobass" data-source="post: 214581" data-attributes="member: 3941"><p>well, since this post I went out and got a NICE 1986 Johnson 6hp.</p><p><img src="https://i459.photobucket.com/albums/qq317/ohiobass/johnson6hp86fullside.jpg?t=1313972170" alt="" class="fr-fic fr-dii fr-draggable " style="" /></p><p></p><p>Had it out this morning.</p><p>It'll push this same boat (1973 12 ft semi V sears gamefisher) around 18-18.5 mph, gps, with me, battery (mounted midship) and bow mount trolling motor. That's compare to the 9.5'ish that the 73 6hp did. :| </p><p>Amazing! The difference between thwe 1973 6hp & 1986 6hp. Prop has some to do with difference. The 73 has a 2 blade, and not sure if correct pitch, but the 86 has a 3 blade 8.5 X 9, and it screams!!! probably hit around low 5,000's rpm at wot with me, tm, battery. 8)</p></blockquote><p></p>
[QUOTE="ohiobass, post: 214581, member: 3941"] well, since this post I went out and got a NICE 1986 Johnson 6hp. [img]https://i459.photobucket.com/albums/qq317/ohiobass/johnson6hp86fullside.jpg?t=1313972170[/img] Had it out this morning. It'll push this same boat (1973 12 ft semi V sears gamefisher) around 18-18.5 mph, gps, with me, battery (mounted midship) and bow mount trolling motor. That's compare to the 9.5'ish that the 73 6hp did. :| Amazing! The difference between thwe 1973 6hp & 1986 6hp. Prop has some to do with difference. The 73 has a 2 blade, and not sure if correct pitch, but the 86 has a 3 blade 8.5 X 9, and it screams!!! probably hit around low 5,000's rpm at wot with me, tm, battery. 8) [/QUOTE]
Motors
