Troutman3000
My lights shorted out after my sister rear ended my trailer. Do I need to replace teh entire system or just the rear lights?
dyeguy1212 said:When she rearended you, did the lights break? There's no way to guarantee the problem is in the lights otherwise, and you'd be best off replacing the whole thing.
If you look hard enough, you can get the whole kit for cheap, and you'll have the peace of mind.
Truckmechanic said:Sounds like you will probably only need to replace the broken light. As mentioned check for power on the wires at the broken light and if you have power, just replace the light.
