Electrical
Trailer Lights
<blockquote data-quote="WaterWaif" data-source="post: 352121" data-attributes="member: 12444"><p>Trust no connection till proven clean and tight. As mentioned use known good bulb for what socket is being tested and grounds the same as all connections. Those blue and the white tap splice connectors were a constant problem when I serviced vehicle/trailer wiring and should be eliminated when possible in my opinion.</p></blockquote><p></p>
[QUOTE="WaterWaif, post: 352121, member: 12444"] Trust no connection till proven clean and tight. As mentioned use known good bulb for what socket is being tested and grounds the same as all connections. Those blue and the white tap splice connectors were a constant problem when I serviced vehicle/trailer wiring and should be eliminated when possible in my opinion. [/QUOTE]
Electrical
Trailer Lights
