Boat House
Trailering Small Outboard Up
<blockquote data-quote="glenbo8391" data-source="post: 252788" data-attributes="member: 8133"><p>I've got a 9.5 just like that, I think Evinrude says its something like 45-50lb. lets say the length of the motor is about the same as a trolling motor, so having the motor on your transom completely parallel to the ground the amount of torque on the transom is the same as running a transom mount 55# trolling motor(actually its a little less because most of the weight on the motor is closer to the transom moving the center of gravity to about half the shaft length, so 55lb*~1.5ft=82lb*ft, trolling motor is 55lb* ~2.5ft?=137lb*ft). Assuming a bump causes 3G's of acceleration, that'd be about 165lb*1.5ft=~150lb*ft. Less than twice that of the 55# trolling motor, I'm assuming that's alot less torque than the motor puts on the transom at WOT. With that small of a motor, I'd say its safe to not have a transom saver.</p></blockquote><p></p>
[QUOTE="glenbo8391, post: 252788, member: 8133"] I've got a 9.5 just like that, I think Evinrude says its something like 45-50lb. lets say the length of the motor is about the same as a trolling motor, so having the motor on your transom completely parallel to the ground the amount of torque on the transom is the same as running a transom mount 55# trolling motor(actually its a little less because most of the weight on the motor is closer to the transom moving the center of gravity to about half the shaft length, so 55lb*~1.5ft=82lb*ft, trolling motor is 55lb* ~2.5ft?=137lb*ft). Assuming a bump causes 3G's of acceleration, that'd be about 165lb*1.5ft=~150lb*ft. Less than twice that of the 55# trolling motor, I'm assuming that's alot less torque than the motor puts on the transom at WOT. With that small of a motor, I'd say its safe to not have a transom saver. [/QUOTE]
Boat House
