Electrical
transducer mounted correct?
<blockquote data-quote="Skiffing" data-source="post: 395030" data-attributes="member: 15889"><p>It does matter which side of the motor the ducer is mounted.</p><p></p><p>For standard rotation prop it should *ideally* be on the starboard side.</p><p></p><p>It can be mounted to port - but manufacturers recommended larger distance between ducer and prop to prevent interference.</p><p></p><p>Grab your FF manual online and see what they recommend then see if yours is far enough away.</p><p></p><p>In my boat I don't depend on the FF when there is less than six feet under the keel. Too much can happen too quickly...</p><p></p><p>And the sonar cone is too small to get meaningful information.</p></blockquote><p></p>
[QUOTE="Skiffing, post: 395030, member: 15889"] It does matter which side of the motor the ducer is mounted. For standard rotation prop it should *ideally* be on the starboard side. It can be mounted to port - but manufacturers recommended larger distance between ducer and prop to prevent interference. Grab your FF manual online and see what they recommend then see if yours is far enough away. In my boat I don't depend on the FF when there is less than six feet under the keel. Too much can happen too quickly... And the sonar cone is too small to get meaningful information. [/QUOTE]
Electrical
