therobzilla
OK,
Here is what I have, and I think I have the correct size for my boat, I could use your expert advice if possible.
Based on this sketch, my "A" dimension on my boat is 15 1/2", now that dimension is not to the lowest point at the center-line of the boat, towards the front of the boat, the "A" dimension if running a straight edged from the lowest point to the top the the transom is more like 17".
Now my dimension of the motor from where is hangs off the transom to the anti ventilation plate is like 17 3/4" on my motor, it's a 1986 Johnson 15 hp.
Based on a bunch of keyword searching on transom heights off this site, it sound like my lengths are correct based on what I have read, and what I have measured, I just was hoping to have someone confirm I'm within range. My ID plate on the new to me motor is missing, and it only identifies what size motor and year it was built, nothing about length of shaft?....
On another note, the motor I'm replacing a Mercury 1979 7.5 hp, the lengths of hanger on the motor to the anti ventilation plates are the same as the Johnson, however I'm not saying it was right when I originally purchased the boat years ago.
Thanks
Rob
Thanks
Rob
