Boat House
Transom Live well drain needed
<blockquote data-quote="MrGiggles" data-source="post: 471493" data-attributes="member: 22613"><p>The upper fitting is called a splashwell drain. Tracker uses a sort of formed aluminum fitting that is not reuable. Have to crush it to remove. You can buy plastic ones on eBay to replace them.</p><p></p><p>On the livewell drain, you need a bronze or Marelon plastic for below the waterline. </p><p></p><p>The livewell pump is mounted in the other hole, no fitting required.</p><p></p><p>You can use any plastic fitting for the bilge outlet, as they are not below the waterline.</p></blockquote><p></p>
[QUOTE="MrGiggles, post: 471493, member: 22613"] The upper fitting is called a splashwell drain. Tracker uses a sort of formed aluminum fitting that is not reuable. Have to crush it to remove. You can buy plastic ones on eBay to replace them. On the livewell drain, you need a bronze or Marelon plastic for below the waterline. The livewell pump is mounted in the other hole, no fitting required. You can use any plastic fitting for the bilge outlet, as they are not below the waterline. [/QUOTE]
Boat House
