Electrical
Trim, Accessories, ignition goes in and out
<blockquote data-quote="DaleH" data-source="post: 435510" data-attributes="member: 15636"><p>Then I'd say you have the wrong bulb for that socket ... look again at the positions for the contacts & the seating 'tits'. Not just that they are there ... but where they are specifically. You may think your bulb is seating and turning to lock ... but it may not be contacting the contacts. </p><p></p><p>Like someone else said, there should be a spring-loaded socket ... maybe the spring corroded and the base (with contacts) is all the way to the bottom ... ? You insert the bulb ... but the contacts don't connect bulb to socket.</p></blockquote><p></p>
[QUOTE="DaleH, post: 435510, member: 15636"] Then I'd say you have the wrong bulb for that socket ... look again at the positions for the contacts & the seating 'tits'. Not just that they are there ... but where they are specifically. You may think your bulb is seating and turning to lock ... but it may not be contacting the contacts. Like someone else said, there should be a spring-loaded socket ... maybe the spring corroded and the base (with contacts) is all the way to the bottom ... ? You insert the bulb ... but the contacts don't connect bulb to socket. [/QUOTE]
Electrical
