Motors
Untreated gasoline...
<blockquote data-quote="huntinfool" data-source="post: 215804" data-attributes="member: 1931"><p>Fuel with Ethanol in it has a shelf life of 23 days. After that the water molecule will start to seperate. Thereby leaving water in your tank. I would treat it as soon as possible and I recommend disconnecting the fuel line from the carb and running it until it dies. (no fuel in the carb) I work on at least 10 a year that customers did not drain the fuel and now have a gummed up carb.)</p></blockquote><p></p>
[QUOTE="huntinfool, post: 215804, member: 1931"] Fuel with Ethanol in it has a shelf life of 23 days. After that the water molecule will start to seperate. Thereby leaving water in your tank. I would treat it as soon as possible and I recommend disconnecting the fuel line from the carb and running it until it dies. (no fuel in the carb) I work on at least 10 a year that customers did not drain the fuel and now have a gummed up carb.) [/QUOTE]
Motors
