albright1695
I am needing to replace the carpet in my boat and I am looking at going with vinyl instead of carpet. What type is best and how well does it bend around the edges of plywood? I will be laying it just like carpet with the recomended adhesive and stapling on the bottom(unseen) side of my storage locker lid. Ive never worked with the vinyl so I am open for all suggestions and info. that you guys can provide.
I will be replacing the plywood on both front and rear decks also. Probably will use marine plywood and wondering what type sealer to use that is compatible with the vinyl flooring adhesive.
Basically looking for some of you guys that have done the vinyl and learn from you.
