Boat House
Water coming over transom
<blockquote data-quote="turbotodd" data-source="post: 452131" data-attributes="member: 7376"><p>If you're getting water coming up over the transom while under way, the motor's mounted too low. Water will run up the leg and over the transom. Raise the motor and the problem should go away-and you'll likely pick up quite a bit of top speed to boot <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite2" alt=";)" title="Wink ;)" loading="lazy" data-shortname=";)" /></p></blockquote><p></p>
[QUOTE="turbotodd, post: 452131, member: 7376"] If you're getting water coming up over the transom while under way, the motor's mounted too low. Water will run up the leg and over the transom. Raise the motor and the problem should go away-and you'll likely pick up quite a bit of top speed to boot ;) [/QUOTE]
Boat House
