So I purchased a used 20hp Johnson. Not really knowing what to look for apparently I got screwed. Guy said the motor would run his boat at around 23 mph and I was happy to hear that. He started it for me and it sounded ok. Figured I would need to rebuild the carb and put new gas lines. Boy was I wrong. I put it on my boat for a test run at the lake. Full throttle only gave me 1 cylinder that was firing. Not knowing what was wrong I started to pull stuff apart. I found that the magneto was very loose. It shifted front to back around 1/8". So I proceeded to pull more stuff off. I found out the crankcase was slightly broken. The ring around the top portion that keeps the magneto stable was missing on half the casing. I know this means i need to buy a new crankshaft housing but... and this is a big but... I made a new piece at work and fit it, and put JB weld on it. Being this piece shouldn't have any real tension on it I figured if it don't work I was gonna have to buy a new housing anyways...
Wish me luck... lol
Wish me luck... lol
