Motors
Which power tilt/trim?
<blockquote data-quote="Fishfried" data-source="post: 472034" data-attributes="member: 24358"><p>Thanks for that post, it really helped explain a couple things for me. </p><p></p><p> I installed the unit last night. Only thing is I had to either lower the unit from the 3/4”-1” to 3/8” above the transom. I could have drilled new holes in the mounting plate but after measuring everything I think the 3/8” will be ok.</p></blockquote><p></p>
[QUOTE="Fishfried, post: 472034, member: 24358"] Thanks for that post, it really helped explain a couple things for me. I installed the unit last night. Only thing is I had to either lower the unit from the 3/4”-1” to 3/8” above the transom. I could have drilled new holes in the mounting plate but after measuring everything I think the 3/8” will be ok. [/QUOTE]
Motors
