Will 3/16 rivet replace these?
CalicoJack
Port Orange, Florida
I am trying to replace leaky rivets but don't know the type or size of them (they go from the bottom of the boat and through the ribs).
I bought a rivet gun that takes 3/16 blind rivets...would those even work?
I don't have the tools for anything bigger.
    128.4 KB
    137.1 KB
They look similar to the rivets on my boat. I believe they are "Brazier" head solid rivets. I've read that most rivets on our smaller tinnies are 3/16" Brazier head solid rivets. Solid rivets are installed by "bucking" them. This is accomplished using an air hammer/air rivet gun, the correct Brazier head rivet tool that attaches to air hammer, and a bucking bar/ piece of flat steel. DaleH has posted very good info on tools and the bucking process.....
BTW...blind rivets are not used below the water line. Blind/Pop rivets are lighter weight and typically used in non-structural areas above waterline....flooring, hatches, livewells, consoles, etc.
https://www.tinboats.net/threads/3-16-brazier-head-rivet-tool-to-set-solid-rivets-10-or-13.41248/
https://www.tinboats.net/threads/solid-rivet-advice-needed.45596/
FWIW I have some 1/4" diameter aluminum "high shear' blind rivets that could be used in that one location. These equal the shear strength of set 3/16" 1100 alloy F-type rivets most boat makes use.
The mandel is likely a 1/8" or 3/32", which most hand rivet tools will tpyically accomodate, but I use the large 'A'-Frame rivet tool to set them (see photo), as you want them set in a looooong slow squeeze (where, yes, sometimes to ratchet up on the mandrel).
But I could sent you 4 for FREE, if you want to try them with your hand tool ... but your hands may ache afterwards ... lol!
Before going to the trouble to removing and replacing them, would it be worthwhile to try to re-buck the existing solid rivets? I don't know the answer. Just tossing it out there.
I think the PO already did that and cracked the aluminum on one of them..
    140.4 KB
CJ spotted it.....Upon closer inspection, both rivets appear to have aluminum hull cracks . That I would believe will take more work than simply adding a new rivet. I'll defer to those with more alum experience.....but I believe something like this:
1. Stop crack from spreading (tig weld)?
2. Repair existing crack (tig weld)?
3. New solid rivet with sealant?
NOTE: Are cracks all the way through hull, as I do not see them on inside...they may be hidden under stringer?
Question: Is this crack from rivet stress on hull, rivet set to hard with air hammer/air rivet tool, or?
I fear this most if I were to replace a solid rivet....air hammer hammers to hard and stresses/cracks hullo_O
Or a good dose of flex seal 😆
My guess: it looks like it was set to hard with an air tool.
Took a closer look ... sorry ...
1) Wet them with West System's G-Flex 650, tin properly prepped/primed of course ....
2) Re-buck them whilst wet and curing ....
3) Reseal again with G-F 650 once the 1st coat dries. Maybe a few coats ...
4) Paint to cover the epoxy
Read my posts on here about using G-F 650, inclusing the PDF from West which shows how much it will flow when the tin is slowly warmed with a hair dryer.
G-Flex 650 ordered🙂
I use it everywhere, even around the house!
Had some cracks in the bricks and concrete on the front stairs. I put in some of that special fine ‘polymeric’ sand used for pavers, then dripped in some G-Flex 650 … since it is flexible … repeated both, then topped it all off with some more of that finishing ‘sand’ and now … no more water penetration, hence no more cracks!
