Hi guys, wanted to run my plan by you guys and see what you think and if it is feasible. For a 2011 Tracker 1648 mod v. This is after months of trying to do research and piece it all together where I have no electrical experience whatsoever.
Accessories: Led light bar and 2 fog lights on bow (12 amp draw total)
5 meters worth of Red 3528 LED lights on the inside gunnels (2.5 meters each side) 4 amp draw I think total.
5 meters of white 3528 LED lights on the outside of boat under gunnels wrapping around the stern near the motor (for water visibility in marshes where I hunt) these strips are the sealed waterproof tube lights.
I have a 4 gang switch panel with 20 amp breakers built in which I want to mount by my seat in the back. I'll be cutting out a spot for it in my bench and running the wires out the back of the bench (through the capped hole that was used for filling the seats with foam) and around the gunnel to front of the boat. My boat has the cubby hole storage under the front deck which is where I want to put the battery and everything (I have the fuel tank in the back on the side opposite from me, and want my side free and clear for me to put my foot back there to lift the motor and also for better boat balance.)
SO my plan is to strap the battery on the side wall of that cubby up front, and attach the fuse block and negative bus bar to that side wall of the cubby hole as well. Then run all the wires back to the switch and then out to their respective accessories, and the negatives of each accessory up to the busbar which will be grounded back to the battery.
I believe at the front since the switch panel is so far away from the Light bar and Fog lights which have a fairly large amp draw, I should be using a 4 way connector (so they run off of the same switch) , followed by a relay so I can connect them more directly to the battery and not have to run as heavy a gauge wire back to the panel? Or is it just as easy to use heavy gauge wire and just run it to the panel and back?
Other than that my light strips don't draw very much power and the only other accessories I might someday get are a fish finder and possibly a bilge which shouldn't be a problem.
This is the way I want to do it, but I am a little uneasy because a lot of people seem to put the battery in the back close to their panel.
