First off, God bless all of you electrical gurus that reply to all of these types of threads. I can't explain how hard trying to figure out this wiring stuff has been, even after reading through all 50 pages of this forum. I feel like I'm trying to learn Chinese algebra! When I finally get this all sorted out, I'm going to make a how-to guide for other wiring newbs like me with a summary of everything I've learned from you pros.
Can you guys look over this picture and help me fix possible flaws with my design please?
The big issues/questions I have so far:
1) I have one PVC pipe running the length of my boat, but I need to run three wires through it: the main 6gauge wire back from the battery as well as the #1 Fish Finder and Bow Light. Can they all be in the same PVC pipe or should I run three pipes separately? (Or maybe run the FF and Bow light tied to the outside of the pipe.)
2) Switch question: I want to keep this simple, so I was planning on buying the 6port switch from Bass Pro Shops that has the fuses built in even though it has crappy reviews. Is there some other pre-made switch I could buy that is better? Here's the link to the BPS switch: https://www.basspro.com/Bass-Pro-Shops-Rocker-Switch-Panels/product/861/100219
It is rated for 15amps, and I'm assuming it is 3amps on each one, but I have to check in the store Friday. I've also have to check my Humminbird 570 and Bow Lights to make sure they need a 3amp fuse and 2amp fuse, but I don't know if I can swap out the fuses that come inside this switch. Anyone know?
3) Anchor light and Bow light: How do I wire these both to the same switch on my panel? Do I buy a "2-peg ground block type thing" and wire them both to this and then wire the 2-peg thing to the switch panel? (I don't know the terminology, sorry)
4)Ground block question: I need to run the negative terminals of all of my devices into these, but should I be using "bus bars" instead? I'm not really sure the difference. Also, I'm running these back to the negative terminal of my battery. Can I use 14gauge wire for these? I have 6gauge for the positive feed from the battery, as well as 6gauge to the trolling motor(w/50amp fuse).
5) LED lights: I read not to connect them in a series, but I'm not sure how to run them in parallel. Do I just run a 14gauge wire to each positive lead back to some sort of "3-peg ground block thingy" and then wire this into the switch panel? It'd be a lot easier just to splice them all together in a row, but I run the risk of them all going out I suppose. Is there any other concern doing them in series?
6) 2nd Battery: Can one battery handle this load? It's only a 40# thrust trolling motor, and the lights wont be used very often. I don't have the 2nd fish finder yet, and the back trolling motor is optional even though I have it (35#thrust). I also have a pull-start 9.9HP motor.
Again, thank you for even reading this thread. It means a lot to me how helpful you guys are. I hate feeling like my boat is going to explode but I look forward to tackling this last major project.
-House
-House
