eshaw said:Pics are worth a thousand words. Without seeing any it's hard to say.
eshaw said:That should be replaced. You could probably cobble up a temporary fix but I'd just replace that one. It appears that it has a pretty sharp bend, you may want to investigate getting a longer cable.
richg99 said:From the picture, it appears to me that the cable is a bit too short. A lot of pressure was put on that fitting. After replacement, any way you can reroute your cable to put less "bend" pressure on that point? if not, maybe a slightly longer cable would be better.
