mcdowellkm
- Joined
- May 26, 2014
- Messages
- 8
- Reaction score
- 0
I know i have never posted here before, but here is my problem. I am a diesel technician so i'm pretty handy with these sort of things usually, but this one has me a little taken back. first lets go through a little history.
Bought my 2003 WeldBilt 18x60 flat bottom boat 2 years ago for a duck/river boat. It has a 2001 Yamaha T50TLR High Thrust tiller on it. When i purchased the unit it had sat for 3 years un-used. Fuel tank was full of nasty stuff so i took it out cleaned with solvent and also replaced the fuel line from the bow of the boat where the tank is all the way back to the motor. Carbs were also full of trash so i took them off, cleaned all 4 of them in untrasonic as well as pulling the jets (both idle and main), as well as the emulsion tubes and throughly cleaned them at the same time. Boat would then (once started) run like a sowing machine. Had a problem with it being hard to start. Would make about 1 revolution then would act like it had a dead battery (or an old chevy with headers causing heat soak in the starter). Fixed this problem by adjusting the valves (which with all the paint that was still on the bolt heads told me had never been done). Now she starts and runs very smooth with no question as to reliability.
Problem is this boat is very slow to plane, as well as when i have it really loaded down (4 guys, guns, dog, decoys) , then it barely gets on plane. when going lighter weight (fishing in summer 2 guys fishing gear) it still takes a while to jump on plane. When loading onto the trailer it's like it doesn't have enough guts to shove itself onto the trailer (which i have never seen a boat that weak). (My dad's 17' lowe jon boat with a 35 merc 2-stroke has no trouble with torque while loading or getting on plane with same loadout as my boat by the way.) First crack of the throttle is real strong but then it falls on it's face almost like it's not advancing the timing correctly But timing is non adjustable on the Yamaha right?. prop is a 13p vengance and the anti-cav plate is 1/2" below the bottom of the boat. also when crusing at wot (i know i don't have a tach on it yet) just seems to me like it's no where near the ideal rpm range at wot. I honestly chucked this up for a long time to this being my first 4-stroke and it being so quiet.
Second problem. This boat will porpoise real bad anywhere above trim all the way down. I have tried moving people to the front and it doesnt really seam to help. I have an 18gal cell mounted in the bow as well as boat has a full 5' deck and 70lb thrust trolling motor mounted on the bow so i would assume there is enough weight up there. I can put people, cooler, decoys in the front and it still wants to bow bounce (porpoise) anytime im higher than trimmed all the way down. in the back i just have 3 batteries (one for outboard, 2 for trolling motor) and myself (250lbs), a tool box in one of the two lockers in the back, and an anchor in the other locker and thats it. Boat originally had a StingRay whale tail on it when i bought it but i noticed it really fought me for steering and caused magor drag on the boat due to the cav plate being lower that the bottom of the boat, plus when i ran it i still had the same plane and low power problems.
Any help or sidection on this would be greatly appreciated.
I have done a compression check which was good, also i only run 93 octane in all my boats with seafoam in them also. another thing i have done is add in an inline fuel filter before it gets to the engine.
