Pale_Horse_Idaho
- Joined
- Mar 13, 2024
- Messages
- 36
- Reaction score
- 28
- LOCATION
- Northern Idaho
So my brand new yamaha F25 with only 40hrs has a heavily rusted woodruff impeller key. Do they not use stainless on the shaft and key?
I am guessing these keys are made of soft steel for a reason. Fresh water use only. If this was a salt water motor that key would have been corroded out.
Why so bad after only 40hrs fresh water?
My question:
Do I need to order a new key (2 flippin weeks to get a key out here)?
Do I wire brush im place and install new impeller?
Do I spray with penetrating oil let soak and then tap one side to rock key back and forth and fall out? Then wire brush key and slot and marine grease it and use it again?
*** The steel screws hold the pump on and lower on bolt into aluminum. They have some white dried hard stuff on them. Is that silicone or dried white grease? I'm thinking its some kind of sealant. What do I use? Dissimilar metals kind of protectant?
I do a new impeller every winter no mater how many hours.
My question:
