freeisforme
- Joined
- Sep 23, 2023
- Messages
- 28
- Reaction score
- 17
- LOCATION
- NJ
I recently inherited a garage full of outboards. An uncle who I suppose was a believer in the thought that you can never have enough spare motors left me roughly 200 or so in his garage.
They range from 4hp up to 135hp with most being in the 40-115 range.
I think a lot of it was because he had a buddy who back then owned a marina and repair shop and he got deals on good used motors all the time. Plus he bought anything that ran so long as it didn't need much work.
Most have been sitting for 10 or so years, or more. Most are super clean for their age being from the middle of PA.
I would venture to guess that every one of them would need a water pump impeller and a carb overhaul, but that's just annual maintenance.
I went through a bunch of them and all have excellent compression and he didn't save junk. There area few parts motors but they're marked as such, and all of those are Chrysler or Mercury motors. There's also a handful of lower units and a couple of odd Mercury motors in the mix as well. I think I saw a couple of older Keikhaeffer 400's (40hp) in the mix, and a few 3hp singles from the 60's or so, but other than a few 10 and 20hp Chrysler motors and one West Bend, the majority are all OMC.
There was two new 9.9hp four stroke Mercury motors but those staying with me.
I'd keep them all if I had the room but we're talking about four garage bays full of motors, all on various racks and stands he had built.
As someone who runs only 14 and 16ft aluminum boats, I have zero use for the larger motors and those will get sold first.
A few that I've listed got zero attention, not even an email. If they're nothing but scrap these days I may be better of just digging a hole and pushing them in it. No matter what, I'll have to load them all up and haul them 300 miles to my place to sell them, its too far to go back and forth if I list them up there. What I may do is load the contents of the place into a couple of trailers and haul it all back to sell so as not to end up being forced to dump anything in a rush if the property sells.
I basically would consider most of these as 'viable' motors, needing the basic maintenance to put them in use again.
There's a few with repair issues, I saw a couple with missing tiller grips, one with a tiller arm removed but hanging from a zip tie, (59 40hp). one with a chipped skeg, a couple with the wrong color lower units, and a few with broken recoil handles where the rope is pulled through or the handle is broken apart from age.
Out of the whole lot, I'm keeping two Mercury four strokes, four 35hp Johnsons, and four Honda 100 four strokes, and I'm not sure yet if I want the Honda motors or not, but a few of them look new. There's also a newer, 2000 something Honda 9.9hp that needs some work, mainly the paint is falling off the cover and the tiller linkage is off the carb somehow, and likely a water pump and carb cleaning of course. It does have good compression, but I have no clue where he got that one, its far newer than most of these motors.
There's a mix of long and short shaft motors as well.
A few have told me that the only way to sell them would be to tear them all apart and list the parts on eBay, but that could take years to sell off and I'd feel like I'm parting out perfectly good motors.
