Float-n-Fly 101
G3_Guy
Kasilof, AK
I wrote this for another forum a couple of years ago and thought it might be worth sharing with my fellow Tinboaters as well. I'm just a guy that really likes to fish for smallmouth... especially in the winter. I hope you enjoy it and find it useful this winter!
Part 1 - FNF Basics
A few notes about the FNF.
- The colder and nastier the weather... the better they bite.
- Water temp has to be between 40-55 degrees for them to really eat it.
- 8-10' spinning rod is a must
- 4lb test P-Line (I prefer the green mono)
- Small pear shaped bobber
- 1/16 Jigs work the best
- Depth fished is usually 7'-14'
This is a dynamite lure for big winter smallmouth! It has been known to catch a few other types of fish as well... Stripe, Crappie, Bluegill, Drum, Largemouth & Spots. Around the East TN area Norris, Cherokee and South Holston produce your larger stringers but Chilhowee, Tellico & Loudon produce a few decent fish with it as well.
I have been using this technique for 12+ years... now that I think about it I am getting old! :( There have been days on all 3 of the top lakes I mentioned above when I could have weighed-in 25 - 28lbs with my best 5 smallmouth. Understand as with all fishing though, not every day is a good day and some of them can even be humbling. It's still a ton of fun though!
A special rod and real is not a must item but for the beginner, it sure makes life a lot easier. I have taken numerous people on their "first" FNF adventure and because we use mostly light line (4lb) the extra length and action of the FNF rod gives the beginner a little more room for error as they learn the technique. Remember... this isn't a flippin stick with 20lb braid on it... you have to get use to giving the fish a little time to run and play. For most of your "power fishing" types, this takes a little time to get use to.
There's no need for you to run out and buy one right now unless you just have the itch and the extra cash... If you do decide you have to have one right away... you can get a good outfit (rod & reel) for around $60 if you're a thrifty shopper. Of course you can always pay more if you want too. :D
There are all kinds of ways to rig your floats, your line, and your flies but the easiest and most consistent way I have found has been just to use a standard small pear shaped float and a single fly. The smaller the fishing line...the better. Determine the depth you want and then wrap your line around the bottom of the float 2-3 times. This allows you to change depths quickly without tying and re-tying each time you want to adjust. I know several people who use the swivel method others have spoke of and have had success but for me, I like to change depths regularly and this tends to slow me down. Everyone likes to fish a little different though, so find what works best for you and stick with it.
The type of banks or cover varies as you really need to get a feel for what stage or pattern the fish are at during the time you are fishing. Rocky banks are always a safe bet but can sometimes be distracting to where the fish are really at and what they are really doing. As a rule of thumb I typically start off in deep pockets and work my way to the points and/or bluffs until I determine their location and/or pattern.
As for warm and/or pressured water... I've caught fish on this lure in all different water temps and conditions, but the issue becomes the quantity & quality. This technique is designed to target suspending schools of fish. During the winter months the smallmouth school up, move less and feed less. The fly which looks like a minnow being drug in front of their faces is to tempting as it takes little effort for them to eat. This is why if you locate a good school, you can land several nice ones in a row. The issue I have run into with warmer water is that the fish typically don't school as much, they move more, eat more and want bigger sized bait. Suddenly this little minnow (fly) that was so tempting during the winter isn't even considered worth the effort during the summer months. Again, they can be caught but not as consistently.
Dale Hollow is a great place to use this lure... I usually make 1 or 2 trips a year down there. The lake is loaded with smallmouth so it's a good place to learn the technique. Norris and Cherokee around East TN are very good as well though.
There are a few other tricks as well but we'll save that for a later time... A guy cant tell all of his secrets at once. :D
Rule of Thumb: If you wake up, look out the window and say... "a man would have to be crazy to fish in this weather", then you should definitely put your cloths on and go on to the lake. It should be a good day!
___________________________
Part 2 - Q&A
Question: When fishing the float-n-fly do you look for schools of shad on your depthfinder @ the right depth or do you just fish certain spots such as bluffs even if no shad are present?
Unfortunately like most things to do with fishing there is no exact answer. The answer to this question depends on several different things such as the time of year, water clarity, temp and to complicate all of those things further, it can also vary by body of water. On South Holston and a lot of your other clear water Appalachian mountain lakes like Fontana & Chilhowee, the SM usually follow the bait in winter which means you should use your graph to locate them. On other lakes like Cherokee and Norris, the bait doesn't necessarily have t be present. I've pulled in on banks with absolutely no bait showing on them and caught lots of fish before. Many times the SM will hold close to a particular area because they know the bait will come there way soon.
It's important to keep in mind that this technique was designed to catch those fish whose metabolism had slowed down and no longer wanted to chase food for the winter. During the cold winter months those SM typically back out away from the banks and suspend in schools. This lure is used to target those fish. While they may not be as active and go looking for food as much in the winter, they will seldom turn down a free meal that swims by right in front of them (your fly).
As you can probably see, there are numerous factors to take into consideration... probably the best advice I can give you would be to practice... practice... practice. Each lake holds its own little secrets. The fun (and sometimes frustrating) part is trying to figure those secrets out.
Question: I would like to know if the Smallmouths, even though are moving slower, can still be found in the same areas of the lakes. I know they won't be on the Bluff ledges but will they just pull out off the bluffs they would be on in summer and suspend in the Winter? If so and you have areas out in open water such as humps that come up out of 40 and 50 foot water to say 10 of 12 feet and hold fish in the summer, Will those same Humps hold Smallmouth bass in Winter too?
I fish bluffs and steep rock banks year round... in the warmer months with jigs and the colder months with FNF... they seem to always produce fish. Remember that even though the main bait for a lot of these fish is minnows, they still feed on Crawfish and other items which stay close to the bottom all the time. So while your fly is usually used to imitate a minnow it can also be used to imitate a crawfish that is hanging out around a rock bank and such. That too may be part of the reason why each body of water is different in the approach that works best for it... some may have larger crawfish populations than others causing the winter fish to hold closer to the shallower banks and bottoms as they depend more on the crawfish to sustain them during the winter. As I mentioned before, this really seems to be the case on lakes like Cherokee.
As for humps... they can be caught there on the FNF but it is not as common as other locations. Most of the success you have fishing the FNF on humps comes in the later stages of winter when spring is quickly approaching. The waters begin to warm, the bait becomes more active, holding closer to these humps which naturally causes the SM to become more interested in these areas. There are a couple of humps on Cherokee that have produced some nice bags in March using the FNF.
I realize that depending on your location, the water may or my not be "fishable" in your area during the winter as your lakes may be frozen over but for those of you who can try it, I hope this helps you this winter!
God Bless & Good Fishing!
good post man! I'm going to be doing a little more FNF this winter... along with throwing that God awful spinnerbait!
Thanks Russ! Let me know if you are up this way this winter. Would love to hit the water with you sometime!
This makes a lot of sense to me now. I also know why I haven't used it or heard of it. I am adding this to one more reason to move out of this frozen tundra. "can fish without drilling holes in ice" ;)
Minnesota Float-n-Fly.
"When it gets cold and fish are not feeding you need to drill a hole in the ice an drop your jig to the bottom and jig 6" off the bottom."
Then because the fish are biting so lightly you use a spring-bobber. The spring will hang the line out and when a fish bites it drops straight down letting you know you a fish is on before its pits out the bait.
=D>
Great info G3....Was wondering do you think that method would work for smallies on Ky lake in the winter ...KY lake is full of smallies too.. But as you know these tenneessee river system lakes don't get as clear as Dale or Cumberland....Have never tried it because of that reason...Old timer here but always looking for some new tricks to try...JIGGY
Thanks guys! I love fishing for bass period but this method of fishing is my passion. It's without a doubt my favorite 4-5 months of the year.
Jiggy - Yes, absolutely! We use it on all the lakes here in East TN. It's just that the few specific lakes I mentioned are where we have our greatest success. I've caught fish on Loudoun and Watts Bar as well and those lakes are not known to be the cleanest or clearest lakes in these parts. Give it a shot this winter! i don't think you will be disappointed. If you are ever over in East TN, let me know and we'll hit the water. :wink:
Will do me friend ...Me and my buds usually make 2 or 3 road trips a yr. I gonna suggest a trip in that direction next yr...JIGGY
Great read. I'm going to try it this winter at Dale Hollow when I get my motor fixed.
