- Joined
- Oct 1, 2011
- Messages
- 459
- Reaction score
- 239
- LOCATION
- SoCal
I am preparing to install a Lowrance 3 in 1 AI transducer on my new Tracker Hull which is painted aluminum.
Lowrance transducer mounting bracket is made of stainless steel.
Reading install instructions from Lowrance, it suggests using a plastic isolating material such as "King Starboard" to prevent corrosion between Alum hull and SS mounting bracket (dissimilar metals).
I was planning on installing SS bracket directly to hull, as I want to use the existing two holes from previous transducer.
However, after reading install instructions, perhaps I should use a piece of King Starboard (HDPE) and screw it into hull using the two existing holes and attach transducer bracket to HDPE.
Will direct mounting bring about corrosion?
Thoughts?
Thoughts?
