- Joined
- Oct 1, 2011
- Messages
- 455
- Reaction score
- 231
- LOCATION
- SoCal
What are all of you using to mount your transducers on alum boats transoms, especially the larger transducers that are nearly 12" long?
Are you screwing directly to transom or are you using a Plastic/HDPE Block?
How are you mounting the block....glue, screw, or both?
I have fabricated HDPE mounting blocks for mounting my last two transducers, which have been large transducers (Lowrance 3 in 1). One was 3/4" thick and the second one was 1" thick. I feel the 1" thick is preferred so you can use a 1" screw length which provides for deeper screw set and increased holding strength. I use #12 screws to mount transducer to HDPE block.
I prefer not to drill holes directly into transom if I can avoid it, but not 100% confident in epoxy between HDPE and Alum.
I mounted my HDPE blocks using 1. Flex Set by Marine Tex and 2. G-Flex by West Systems. Both of these claim they will bond aluminum and HDPE. I used flame treatment on both applications.
I did not use either boat long enough to determine durability/adhesion.
They appeared to hold up well, but no real data on how they will hold up after time with higher speeds (20+ mph) over time.
On my new Tracker aluminum boat (yet to receive), I reconsidering how to mount the transducer. I do not want to screw directly to transom, so HDPE blocks will be used. To Glue, Screw, or Both are my questions?
Here's what I have been reading about. Most HDPE blocks are available in 3/4" thick and either small or large sizes (LxW):
1. Stern Saver (now out of business but still available at some retailers) that uses a special proprietary blend of epoxy (3/4" thick). It uses epoxy to mount.
Stern Saver
2. Stern Pad made by Seaworthy Innovations. It uses 3M VHB tape to mount. Claims to be waterproof. (3/4" thick).
Stern Pad.
3M VHB
3. There are various HDPE blocks sold that use two stainless #10 screws and some silicone or 3M 4200 to seal the the two screws and help with bonding. (3/4" thick). They use two screws to mount.
Mounting Block
HDPE Block
4. RyTek, Canadian made, 1" thick with milled grove near perimeter for sealant/adhesive. Uses two screws to mount.
Heavy Duty Mounting Block
Stern Saver
Stern Pad.
3M VHB
Mounting Block
HDPE Block
