MTBF
Hey Guys! I've been a long time "looker" on this forum over the years. Even made a name on here with a 12' boat but never ended up doing the project, renting a 14' Lund for the last 4 summers I had to find something for next season. I fish 2-4 weeks every year on smaller lakes in Northern Ontario so a 16'+ wasn't needed as I've been very comfortable in the 14' Lund WC just the 9.9 4-stroke Yamaha has always been the culprit for slow speed although reliable I told myself if I got a boat I would have double the hp or more.
A week or 2 ago a good friend of mine hooked me up on a sweet deal. It's a older Mirro Craft 14' Aluminum Boat. Has a decent trailer and a mid 80's I'm guessing Evinrude 20hp 2-stroke. Wish I can figure out the year of the boat by the name plate but it's work off and just shows the 35hp max where it was built etc.
Here are some pictures, the boat was bought under the impression I had to replace all the wood and carpet in the boat. So in March 2016 when the snow is gone I'll empty the boat out, re-make the floors and deck etc. My idea is to make the side compartment 15-17" wide on the top with the same height. Right now it barely holds 3 rods at 7 or 8" wide so growing that compartment will be job number 1. Then moving the passenger seat more to the middle of the boat. I will counter act the weight by probable storing both my battery's and gas on the right side of the boat. Well half to play with the weight balance on the water.
So after fixing the side box I want to play with the casting deck. It's ridiculously low for my liking and I don't want to stand on the top of the boat so a generous 6-8" rise of the front deck, pushing the oversized bow box back too making it just big enough for a trolling motor and fish finder. One compartment door in the deck, bow box, and side box.
I'm under the impression the main floor is sitting on layers of styrofoam so I'll have to borrow ideas on how to make the deck structure. I've seen lot's of great reno's on here if you guys think one hits the spot please share below. I know nothing about wood but have been told not to cheap out and go all out and buy Marine Grade Plywood(3/4" for my deck and main floor) I'll probably go 1/2" on the bow box and side box. About the framing what wood/cut's do you guys recommend? I see what looks like thinner 2x2 framing and I've also seen bigger 2x4 framing.
The boat will have 2 guys under 200lbs in it with the odd "boat ride" with 3-4 people. My extra 2 passengers will sit on the deck and side bow box I hope.
I forgot to add this is my first boat! Very excited!
My dad ripping the little 30lb Motor Guide off the front.
Not the best picture but this boat does not have a Mirro Craft decal rather a hard plastic logo at the rear.
Inside shot, pedestals are solid and swivel bases work fine. Some new paint and they will be perfect. Seats have no rips so again some elbow grease and I got my seating taken care of already! Bow box is too big and comes down on a angle where I want a 90degree flat front on it with the triangular top.
From front to back, with some adjustments the side box should be able to take a pair of straps to hold my rods down as well as work as a tackle storage box. Just needs to be brought out more in width.
Bow needs a good clean up
The back of the boat. Kind of like the little top over the past gas tank and mini lid over the drain plug. I'd like to cut out the other side too for a bilge pump.
All cleaned out ready for storage this fall/winter
I'd like to know how all the rain water will find it's way under the flooring. Do you guys drill holes or cut notches out on the sides of your flooring? Anyway that's it for now as far as pictures. Trailer needs some paint and sanding, new winch maybe too. The motor has sat for 6 years. Needs the carb drained, good news is it turned over and we sprayed some oil in the cylinders gears aren't locked up might run it in the yard before fall do a good winterizing on it and be done.
My questions are spread throughout the post but please all advice welcome just ain't going to change my layout that's all. It's getting the building materials done right that is my main goal!
Cheers guys,
Mike
Cheers guys,
Mike
