LaqueRatt
- Joined
- Feb 24, 2023
- Messages
- 685
- Reaction score
- 392
- LOCATION
- Cedar Lake, IN
X2.Check for something blocking the tell tail opening or hose.
I reviewed the procedure for servicing the water pump and it doesn't look terribly hard.
Thanks for the suggestions. I'll give that all a try. I still wonder though if this motor is designed to pee like a guy or pee like a girl....LOL Think I've seen vids of this motor that didn't produce a real stream. It does seem like it should push more water though, so maybe I'll just bite the bullet and swap the impellor out. Since I don't plan to keep it, I'd like to move on to something else, but don't want to drop problems into somebody else's lap either.
That was the way my Evinrude 9.9 worked when I got it. There is a modification you can do to get a telltale stream from it. I did it to mine and it worked perfectly. I have included one link to a video on how to do it.If I'm not mistaken, those didn't really have a telltale "stream". All you will see is the spray/dribble out of the exhaust ports on the midsection.
