RaisedByWolves
As stated.
Shifting from fwd to neutral is hit or miss. Shifting from rev to neutral is easy.
Is there an adjustment for this?
The shift rocker sits in the detent either way, but shifting from fwd to neutral softly (Normally) leaves it in gear but if I hit the shifter with a harsh rapid movement it goes into neutral fine. Its like I have to go past the detent and then back to it to make it hit neutral.
Not a huge deal but it makes docking more challenging than it should be.
