- Joined
- Jun 20, 2023
- Messages
- 426
- Reaction score
- 451
- Location
- Berkeley springs WV
- LOCATION
- Berkeley springs wv
Finally got my 2nd house/starting battery installed along with the 36v lifepo4 tm battery. Hardest part was getting the 10feet of 4ga wire from the battery in my center console to the back of the boat. My boat has channels for wire and hoses but they were already almost filled to capacity.A fish tape was just barely able to get them through. The area where everything is tied into the blue seas dual bus bar is still a bit of a mess. There are a lot of wires for all the accessories. I'll spend some time with zipties and a label maker one day to tidy it up a bit more. I did get most of the center console wiring cleaned up. I mounted a piece of pvc board for the breakers and onboard charger inside the console. Let me tell you a 6ft2 215lb man doesn't fit well inside that tiny center console. As you can see by the pics there is a awfull lot of wiring on this boat. I'll be glad to have a true master power switch now no more things getting turned on from a bump in the road while trailering. Why xpress wouldn't have don't that from the factory is beyond me. I've never owned a boat with this many accessories wired in...it was a bit daunting looking at all those wires and lord help me if I ever need to replace any of the pumps buried under all that wiring but it's done. Time for a beer or three.
