- Joined
- Oct 1, 2011
- Messages
- 453
- Reaction score
- 230
- LOCATION
- SoCal
I am at the beginning stage of planning a small bow deck so I can a TM. and one group 27 battery. This deck is to be created above the forward-most crossmember seat/bench and use the rear vertical section as the aft wall of the deck (pic).
First step was to remove the front section of deck and take a look under the forward-most cross member/seat. Previous owner stated he added two 50# led bags under this area to assist boat getting on plane. BTW...Boat performs great with this added weight.
I found the the lead bags and removed them. I also found an alum bracket he fashioned and riveted to one stringer and to a front alum factory panel. I'm assuming this bracket was installed to stabilize and trap bags up forward (pic).
Now after partially removing the forward section of the forward-most floor section (it's alum), I noticed that the floor has been rubbing against hull and has created two issues: 1) rubbing and weight of standing on floor has created a detent in hull (see pics). When I rub my fingers over this area I can clearly feel this detent. 2) Alum hull appears to be wearing down (pics).
My concerns: 1) detent may cause issues 2) if floor is left rubbing, it will rub through the alum hull. Hull and sides are 0.065" thick.
Floor is factory. Forward-most section (one discussing here) is alum covered in vinyl and rear floor sections are 3/4" plywood covered in vinyl.
My plan was to add a battery under the forward-most bench (pic), as I wanted weight as low as possible. I would have to build a sub-floor in this area (pic) to accommodate the battery. OR...I could install battery on top of the bench since it will be covered under the TM deck I am building (pic).
