WaltonsMountain
- Joined
- Aug 8, 2009
- Messages
- 54
- Reaction score
- 0
I would like to start a discussion on the pros and cons of carpet vs bed liner. I am just about to do the inside of my 12' flatbottom. Steelflex is going on the outside hull but i'm stumped about what to do on the inside. I know that i'm going to be putting in a low plywood floor in middle and front sections but I dont know what to put on top of it. I can either seal the plywood w/ Thompson's and then put carpet on it or simply spray a bed liner type of material over the wood. I'm not too worried about leaks or sealing the inside because the Steelflex will do that job on the exterior. What are the pros and cons of each?
Weight is a significant factor in my decision because i'm already nearing my limit. Also, traction is a big thing for me. I dont want to be slipping around. Also, which holds up better over time? Please discuss the pros and cons....
