- Joined
- Feb 3, 2023
- Messages
- 658
- Reaction score
- 598
- LOCATION
- Mead Washington
Negative. They are waterproof but they don’t float. Don’t ask me how I know.I hope they float!
Maybe a little inflatable remote life vest is needed here?The size of the float needed to get neutral buoyancy would be very large. I mean....It's not a set of boat keys.
The power of the outboard could over power the steering of the trolling motor and cause a problem. The speed needs to be down so the trolling motor will be able to steer. I have an electric outboard and it will push the boat right past a turn if it's running on high, a gas motor would certainly push more. You are using the TM to steer with for trolling so at that speed things would work. I have only used my emergency track once for an emergency. I got caught up in the fishing and stayed too long, darkness made navigation impossible. I deployed the TM called up the track back to the dock and sat back and blindly returned. Most times I use the "emergency" tracks to be able to get out and to return and be able to do setup and pack up without needing to steer. Of course this only works when boat traffic is light, other boats will cause interruptions.@CRS, I continue to learn a lot on this thread. The way you connect tracks to avoid a sharp turn makes a lot of sense. Thanks for sharing these points (no pun intended).
I also use the outboard when trolling and steer with the TM. The part I highlighted above -- are you talking about if you ever had to use the emergency track or using iTrack in general. Seems iTrack should work with an outboard motor running, as long as we don't turn the boat with it.
When the wind is strong I use the outboard to assist the TM and that works great.
Something I missed about the tracks before to keep in mind, being point to point when you start be sure that the direction of the nearest point is in the direction you want to go. If the nearest point is in the opposite direction the boat will head for it then make an abrupt 180 to go the intended direction. The points are not displayed so be ready to stop the track and manually steer a bit farther in your desired direction. This is only a problem if you have lines out.
I agree - some nice information here.
6.5 ounces? Ouch! That's pretty heavy, but I guess half of it is battery weight.
I'll have to get used to the remote. I'm used to the tiny Copilot/Autopilot remotes. I wear mine like a watch most of the time. Or buy one of the mini remotes that I'm seeing on Ebay.
The ipilot link remote weighs in at 7.8oz.I just weighed mine. 6.5 oz (or 0.4 pounds). I agree, a floatie might be asking too much.
That's a good point. I am usually fishing over deep structure, (Spot lock!) but I sometimes troll the edges of the grass beds early morning. That is why I'm excited about being able to record a track.I can see how the remote could be a pain in the neck depending on your fishing style. For me, it isn't an issue when I'm trolling, which is most of the time. Using the remote for occasional corrections doesn't interfere with fishing. If I were working a bank over by tossing rubber worms I could see how it might be more of a pain. Foot control might be preferable in that case, IDK.
Oh, I like that idea! Sounds better than having something bouncing off your chest all day.I use a pear shaped carabiner with a short strap attached to a belt loop.
That's exactly how I use it....it actually comes with all the components to hang it like that.
It's an extremely simple conversion. good luck.It's warm today. I think I'm going to go pull the TM and upgrade it this evening. Looking forward to this!
