Johnson 20 troubles
fowlmood77
Williamston, SC
Having problems getting all the power out of my motor. She revs fine and has power out of the water, but when under load I am getting no where near the top end I use to get. I thought it might be the dreaded ethenol problems so i took apart the carb the other night. Everything looked good, so I did a compression testand found 120 on both cylinders. I am stumped to what might be causing the power loss. I did find one plug that had a little wet fouling on it. COuld this cause a drastic loss in power? It is almost like I added 500lbs to the boat, but nothing like that has changed.
dude I had the same exact problem with my Johnson 20... ended up being either bad gas or a bad ratio mix. I emptied the gas tank and put new gas/mix in and that sucker is back to where it used to be again
Am I reading it correctly that it's running well or atleast sounds like it is?
Compressions good.
I'm thinking spun hub....
The wet plug leads me to believe that he has a non firing cylinder.
They will run like a banshee without a load on them even though they have dropped a cylinder.
