- Joined
- Oct 1, 2011
- Messages
- 460
- Reaction score
- 240
- LOCATION
- SoCal
I am at the installation step now where I am preparing my 2 LiTime 12V/100amp Trolling Motor Edition batteries for use on my 24V NEW Terrova.
According to LiTime Product Manual, the first step in preparing batteries for use is to charge them individually with the appropriate Lithium battery charger.
I am using my new NOCO GenPro 10X2 charger. I set to lithium mode.
Prior to charging batteries were at 13.1V/13.2V, This is the same voltage as when I received them a few weeks ago,
I charged the two batteries for 17 hours. At this point, charger indicated "maintenance" stage with the slow pulsating green LED light.
I allowed the batteries to settle for a couple of hours (per manual). Voltage is 12.85V
Next step is balancing batteries. Before this can be done, batteries are supposed to be at 13.33V at rest (after being fully charged).
At this step batteries need to be connected in "parallel" for 12-24 hours. This is supposed to balance vols in each battery.
After this step, batteries can now be placed into service.
I did not balance batts as they did not reach the 13.33V that is needed prior to balancing.
Questions for those of using these LiTime batts:
1. Why did voltage drop from 13.1V prior to charging to 12.85 after 17 hours of charging and being "fully" charged?
2. What did you experience when you performed both the charging and balancing step....voltage after charging? Voltage after balancing? What charger are you using?
I have emailed LiTime and awaiting a response.
Thanks!
Thanks!
