- Joined
- Oct 1, 2011
- Messages
- 456
- Reaction score
- 232
- LOCATION
- SoCal
I ended up using these....with some rubber/plastic covers (pics below).
Marine Battery Terminals
Connected NEG starter cable to new marine clamps threaded 5/16" post and 2 AWG from new marine clamps 3/8" POS to ON-OFF switch.
Battery Charger cables and NEG house wires are connected to the battery's 5/16" threaded posts. I used single post silicone covers for the wires on the battery's threaded 5/16" posts.
The issue with most terminal covers....they do not work well when you have 2-3 cables coming off the the threaded posts, ex...leaving post at 4, 6, 8 O'Clock; the covers are best suited for single cable use. That;'s what I like about the Military clamps...the cover covers both cables.
If you think the Military clamps are expensive, then take a look at these! BTW...the hard plastic covers cover ALL of the battery LEAD.....added brass plate, heavy post and 5/16" theaded post. This appears to be a Mercury exclusive item....I have not seen any knock offs that include covers that cover ALL terminals. The video shows them installed.
CONS: 1. Brass plates are drilled at 5/16" and 3/8"...however marine batts are both 5/16"
2. Brass Plates attach to threaded post...weakest part of battery terminals.
Hard to find.....
https://www.google.com/shopping/pro...&ved=0ahUKEwiq4KCcv6mEAxUFIEQIHU8BCicQ9pwGCAw
Hard to find.....
