FormerParatrooper
This is my 1979 14ft Mirro Craft F4604 Limelighter Resort. The outside was roller painted with Duralux boat paint, and the inside was done with Rustoleum spray paint. I wanted to get rid of that awful lime green color. I do not paint well, but I think for my purposes this is coming along. Boat, trailer, motor (1967 Johnson 9.5) and a trolling motor (Minn Kota PowerDrive 665) set me back a whopping $700.
Future plans are too add a removable floor, add carpet to the seats and a small deck from the front seat to the bow. I added a piece of ¼ inch thick aluminum plate to the transom where the motor sits.
I will be running wire thru the gunwales for the lights, replacing the existing wire there that is way too thin for a 12v marine battery. I think the best place to put the battery is in front of the forward seat where the previous owner had it. From the bow to the battery will be a short run for the lights and then a longer run of either aluminum conduit or “smurf” tube under a removable floor to the transom for the trolling motor.
Trailer will also be getting a new look. The existing side lights are broken and the rear lights seem dim. I will be using a kit to do the new lights with new wire. According to a rep from EZLoader, the trailer is a 1978, 15 U 1650. Already had bearing buddies on it and they seem to work well. Some surface rust on the underside of trailer, some elbow grease and repainting will take care of that.
Any faults in the above ideas or something I need to rethink?
