Plywood finish question
Fish Fighter
Middle Georgia
If I use spar urethane which is oil based on the plywood deck, can I then cover it with Tuff-coat covering that is water based?
Well, out of the 34 people who looked at this question I haven't received any input. I thought this site would be helpful. Guess not!
Sorry I can't help ya with that one. I always sealed the plywood decks with epoxy resin and fiberglass cloth. That way I could paint whatever I wanted or glue down vinyl or carpet whatever my choice was for the application.
One other thought maybe check with the manufacturers of each product and see what they say about applying one over the other.
[url=https://www.tinboats.net/forum/viewtopic.php?p=339575#p339575 said:
WVfishnfool » 4 minutes ago[/url]"]One other thought maybe check with the manufacturers of each product and see what they say about applying one over the other.
That's what I'd do - My guess is, you should use a primer between the two. I believe tuff-coat (which I used on my build) has a primer as well - I didn't use the primer, becuase I could scuff up the aluminum plenty enuough with a wire wheel on a drill.
Sidenote - I'd be a bit more patient with your questions being answered when asking for help before criticizing fellow forum members. It might turn away folks who actually have the answers you're looking for.
[url=https://www.tinboats.net/forum/viewtopic.php?p=339572#p339572 said:
Fish Fighter » Fri Jan 24, 2014 10:16 am[/url]"]Well, out of the 34 people who looked at this question I haven't received any input. I thought this site would be helpful. Guess not!
Better then 34 wrong answers! But hey, now you have something to complain about so it is all good :LOL2:
[url=https://www.tinboats.net/forum/viewtopic.php?p=339574#p339574 said:
WVfishnfool » Today, 10:48[/url]"]Sorry I can't help ya with that one. I always sealed the plywood decks with epoxy resin and fiberglass cloth. That way I could paint whatever I wanted or glue down vinyl or carpet whatever my choice was for the application.
Thanks, I just need ideas, this helped.
[url=https://www.tinboats.net/forum/viewtopic.php?p=339577#p339577 said:
Brine » Today, 11:08[/url]"]
Thanks, this info is what i was looking for. I didn't mean to sound like i was criticizing but time is precious, and when I get extra, I like to use it. Sorry if I offended anyone.
[url=https://www.tinboats.net/forum/viewtopic.php?p=339620#p339620 said:
agentxman » Today, 16:31[/url]"]I just redid my transom wood and i used Fiberglass resin. About 2 coats should be fine.
Thanks
agentxman » Yesterday, 16:31[/url]"]I just redid my transom wood and i used Fiberglass resin. About 2 coats should be fine.
Polyester resin is useless by itself, it has to be used with fiberglass cloth or mat or it will crack and peel off over time (about a year or two), but you'll find that out later.
I can't answer the boat specific part. When it comes to paint in general you can also put oil over Latex but latex over oil often peels and flakes.
Like the others mentioned, I would seal with Epoxy and paint with whatever I wanted.
[url=https://www.tinboats.net/forum/viewtopic.php?p=339724#p339724 said:
jigngrub » 25 Jan 2014, 12:58[/url]"]
Ditto this.
Thanks for all the help, I guess I will go with the two part epoxy that goes with the Tuff-coat flooring. I just want to make sure it is sealed well enough so I don't have to do this again in a couple of years.
