Douglasdzaster
- Joined
- Sep 19, 2020
- Messages
- 780
- Reaction score
- 459
- Location
- Smithville,Texas
- LOCATION
- Smithville, Texas
I figured I better start a new thread sin this is going to end up being a rebuild.
About 18 months ago I bought a 1983 16/52 Monark with a 40 hp Yamaha.
First thing I had to do was go through the motor and completely redo the fuel system since it didn’t have a single fuel filter. The hose was bad , clamps rusted and the carburetors had to be completely rebuilt. They where eat up with corrosion. I went ahead and replaced everything but the housings which I spent hours cleaning up. I used the boat for a while until I decided to look under the floor and see if it needed cleaning underneath. Evidently it had never been done and the boat must have seen saltwater. That explained a lot of what I had to do to the motor.
From looking at the top of the floor it was fine. I found a sheet of 3/4” plywood that looked treated and old. The rest of the floor was made up of log metal signs that where holding moister between them so it stayed damp under there. The aluminum was pitting from all this.
So I spent many hours getting it down to bare aluminum and abatement of the corrosion in the pits. Then just applied polish for several months to make sure i didn’t miss anything.
So here we are I’ve repainted and in the middle of a new flooring system that is completely removable anytime I want to inspect underneath. Also replacing all the fasteners on the boat some where corroding the aluminum around them. The work I did was with stainless steel screws and bolts and looks good but they’re going to.
I’m avoiding any new holes if possible and I’m using aluminum rivnuts.
Ill be painted the rest of the boat as well as flipping it and stripping the bottom then applying the toughest , slickest stuff I can find. After the floor comes the front deck.
Meanwhile adding upgrades as I go. I’m want to set up for multiple rod holders. I’m thinking of some T track. With the hardware I can build a 4 rod holder for around $50. I’m going to start by mounting T track along the transom on both sides of the motor and using Drift masters I can take off when not using. That covers trolling. I’m trying to figure out the gunnels where I could put several rods for drift fishing. Problem is the top of the gunnels are round and only one inch.
Anybody have a rig I could see a picture of or anyone have ideas to share On how to get the track along the gunnels?
