You could...
But for what it's worth, if you use solid rivets, it's cheaper and faster and the results are better.
It may seem daunting, but once you learn how to install them, it's a game-changer! Now you can make ANYTHING!
Also, you will find that using a sharp wood chisel to pop the heads off the rivets and then tapping out the tails with a nail set or any kind of punch is WAY faster than trying to drill each one out perfectly, with little risk of damaging the hole.
So the process is "DINK" (off comes the rivet head) TAP TAP TAP (out pops the rest of the rivet) then you put the new rivet in, and TAP TAP TAP (you set the new rivet in place with something heavy behind it)
After a few, it becomes a really fast process. It helps to have a second person around, especially when working on the bottom of the hull, but the same applies if using nuts and bolts.
Also, when putting things back together, I like to use 3/16" pop rivets in a few spots to hold everything together and in place. Then you can set your solid rivets or even your nuts and bolts comfortably.
Another thing you will want to have on hand is a decent awl, as the holes tend to not want to line up when you put things back together for whatever reason, probably temperature differences. When that happens, push the awl through the holes at an angle, and then straighten to align the holes. Put pop rivets in as you go, if there are a bunch. After awhile, everything will line up like it originally was. If you drill new holes, you will often have puckers in the finished result, so take the time to align the holes.
Best wishes with your project!
